Aller au contenu principal
Acer Iconia Tab A501 Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Iconia Tab A501 Motherboard Replacement, Back Cover: étape 1, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement, Back Cover: étape 1, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement, Back Cover: étape 1, image 3 de 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
  2. Acer Iconia Tab A501 Motherboard Replacement: étape 2, image 1 de 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
  3. Acer Iconia Tab A501 Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Remove all tape from the device.
  4. Acer Iconia Tab A501 Motherboard Replacement: étape 4, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 4, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    $3.99
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
  5. Acer Iconia Tab A501 Motherboard Replacement: étape 5, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 5, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 5, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the four 4.0 mm Philips head screws connecting the battery to the motherboard.
    • Take out the battery.
  6. Acer Iconia Tab A501 Motherboard Replacement: étape 6, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 6, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 6, image 3 de 3
    • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the folded, white ribbon cable.
    • Remove the folded, white cable.
  7. Acer Iconia Tab A501 Motherboard Replacement: étape 7, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 7, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 7, image 3 de 3
    • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the straight, white ribbon cable.
    • Remove the straight, white ribbon cable.
  8. Acer Iconia Tab A501 Motherboard Replacement: étape 8, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 8, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 8, image 3 de 3
    • In this step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the cable with red, white and green wires from the beige connector slightly in from the docking port.
  9. Acer Iconia Tab A501 Motherboard Replacement: étape 9, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 9, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 9, image 3 de 3
    • Unscrew the 3.0 mm Phillips head screw on the speaker near the Micro-HDMI port using a Phillips #1 screwdriver.
    • Unscrew the 4.0 mm Phillips head screw on the speaker near the Micro-HDMI port using a Phillips #1 screwdriver.
    • Remove the speaker.
  10. Acer Iconia Tab A501 Motherboard Replacement: étape 10, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 10, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 10, image 3 de 3
    • Use the flat end of the standard Spudger to disconnect the two small, rotatable connectors attached to the wireless adapter.
  11. Acer Iconia Tab A501 Motherboard Replacement: étape 11, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 11, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 11, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
  12. Acer Iconia Tab A501 Motherboard Replacement: étape 12, image 1 de 2 Acer Iconia Tab A501 Motherboard Replacement: étape 12, image 2 de 2
    • Carefully slide the adapter out to remove it.
  13. Acer Iconia Tab A501 Motherboard Replacement: étape 13, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 13, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 13, image 3 de 3
    • Use the wide end of the standard Spudger to take off the rotatable connector to the 3g antenna below the rear-facing camera.
  14. Acer Iconia Tab A501 Motherboard Replacement: étape 14, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 14, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 14, image 3 de 3
    • Use the angled tweezers to disconnect the cable with red wires from the beige connector opposite the docking port.
  15. Acer Iconia Tab A501 Motherboard Replacement: étape 15, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 15, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 15, image 3 de 3
    • Use the tweezers to remove touchscreen connector from the motherboard.
  16. Acer Iconia Tab A501 Motherboard Replacement: étape 16, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 16, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 16, image 3 de 3
    • Use the angled tweezers to disconnect two microphone connectors, which are above the orange-brown touchscreen connector and next to the battery space.
  17. Acer Iconia Tab A501 Motherboard Replacement: étape 17, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 17, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 17, image 3 de 3
    • Use the plastic opening tool to flip up the locking mechanism to the white front camera port just above the rear-facing camera.
    • Disconnect the camera cable from the motherboard.
  18. Acer Iconia Tab A501 Motherboard Replacement: étape 18, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 18, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 18, image 3 de 3
    • Use care in the next step.
    • Use the wide, flat end of the standard Spudger to disconnect the display connector from the large, metal port next to the battery space.
  19. Acer Iconia Tab A501 Motherboard Replacement: étape 19, image 1 de 2 Acer Iconia Tab A501 Motherboard Replacement: étape 19, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the four 4.0 mm Phillips head screws holding the motherboard in place.
  20. Acer Iconia Tab A501 Motherboard Replacement: étape 20, image 1 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 20, image 2 de 3 Acer Iconia Tab A501 Motherboard Replacement: étape 20, image 3 de 3
    • Remove the motherboard.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 542
