Aller au contenu principal
Acer Nitro 5 AN515-53-55G9 Display Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-53-55G9 Display Replacement, Display: étape 1, image 1 de 2 Acer Nitro 5 AN515-53-55G9 Display Replacement, Display: étape 1, image 2 de 2
    • Make sure laptop is off and unplugged before beginning replacement.
    • Open the laptop so the display is facing you.
  2. Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 2, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 2, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 2, image 3 de 3
    • Pry open the plastic bezel around the screen by going around all four sides with a plastic opening tool.
  3. Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 3, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 3, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 3, image 3 de 3
    • Remove the four 9 mm screws holding the display in place with a Phillips #0 screwdriver.
    • Carefully lower the display to rest on the keyboard.
  4. Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 4, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 4, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Display Replacement: étape 4, image 3 de 3
    • Disconnect the display connector from the display.
    • Remove the display.
7 autres ont terminé cette réparation.
3 commentaires
This guide was helpful in replacing the screen in my son’s Acer Nitro 5 AN515--43-R0YM, with a slight difference. That model’s screen is held in place with adhesive strips, not screws. Kind of pain, but not too bad to deal with. The strips work basically like 3M Command Strips. Use pliers are strong tweezers to grab the tab peeking out from behind the screen at each corner (but do one at a time, of course), and _slowly_ pull straight out (parallel to the screen). Once enough has come out, grab with your fingers and keep pulling _slowly_. If you pull too fast it could break, and then you’ve got a real headache on your hands. Be patient and eventually the tape will release.
Matt - Réponse
I've use it for a AN515-52 and the steps are the same. I did a screen replace in less then 15 min. Top guide
FoefuR - Réponse
nice 15 min is it hard for a beginner
Patrick Flynn -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 87
30 derniers jours : 340
Total : 18,603
