Introduction
This guide will walk you through the process of replacing a damaged or dead display in an Acer Nitro 5 AN515-53-55G9. If your display is cracked, has lines running across it, or otherwise won’t turn on, this guide will help you to replace it with a functioning version. You can narrow your problem down to the display by hooking up your computer to an external monitor before performing the replacement. If your computer functions perfectly fine when connected to an external monitor, the issue is most likely caused by a malfunctioning display.
If your display is cracked excessively, it may be helpful to lay some clear tape over the display to prevent cutting yourself on the glass shards. Just be sure not to cover the plastic bezel, as you will need to remove it to complete this guide.
Ce dont vous avez besoin
9 autres ont terminé cette réparation.
5 commentaires de tutoriel
This guide was helpful in replacing the screen in my son’s Acer Nitro 5 AN515--43-R0YM, with a slight difference. That model’s screen is held in place with adhesive strips, not screws. Kind of pain, but not too bad to deal with. The strips work basically like 3M Command Strips. Use pliers are strong tweezers to grab the tab peeking out from behind the screen at each corner (but do one at a time, of course), and _slowly_ pull straight out (parallel to the screen). Once enough has come out, grab with your fingers and keep pulling _slowly_. If you pull too fast it could break, and then you’ve got a real headache on your hands. Be patient and eventually the tape will release.
I've use it for a AN515-52 and the steps are the same. I did a screen replace in less then 15 min. Top guide
nice 15 min is it hard for a beginner
Hi, mate I'm just wondering what the problem with my laptop Acer Nitro 5 is when I turn it on its almost the entire screen is black but after a while probably 40-50mins time the screen is working fine with flickering on the top portion of the screen and after 10-15 mins the flickering is gone. I also try connecting it to external monitor and it's working fine, Thank you in advance for your answer. Cheers
How to fix my acer nitro 5 AN515-57-53SB? I'm just playing Valorant Game then suddenly the screen starts to have some kind of glitches, the dislpay is okay and then every second it starts to glitch
