Aller au contenu principal
Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 1 de 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 2 de 2
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 2, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 2, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Use the Phillips #0 screwdriver to remove the 9mm screw in the bottom left corner of the RAM tray covering.
    • Remove the RAM tray cover by prying it up with a plastic opening tool.
  3. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 3, image 1 de 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Remove the screw on the Hard Drive tray with a Phillips #0 screwdriver.
    • Lift up the tray covering using a plastic opening tool.
  4. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the fourteen 9mm screws holding the back cover in place.
    • Remove the hard drive (if applicable) from the slot prior to removing the back cover.
    • This device didn't have a hard drive so your device may look different.
  5. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 5, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 5, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 5, image 3 de 3
    • Carefully remove the back shell from the device by prying at the creases with a spudger around all the edges.
    • Do not forcefully try to separate the shell as you may cause harm to the shell.
  6. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Lift the back cover off once all the clips have been disengaged.
  7. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 7, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 7, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 7, image 3 de 3
    • Using your fingers, disconnect the white and black cables connected to the left side of the Wi-fi card.
  8. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 8, image 1 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 8, image 2 de 3 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 8, image 3 de 3
    • Remove the screw holding down the Wi-Fi card with a Phillips #0 screwdriver.
  9. Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 9, image 1 de 2 Acer Nitro 5 AN515-53-55G9 Wi-Fi Card Replacement: étape 9, image 2 de 2
    • Slide the Wi-Fi card out from its port.
1 commentaire de tutoriel
My hard drive got disconnected and I can't locate where is the place to connect it
manueltopete59 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 58
Total : 7,136
