Aller au contenu principal
Acer Nitro 5 AN515-55 SSD Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-55 SSD Replacement, SSD: étape 1, image 1 de 1
    • Shut down your laptop.
    • Make sure your laptop is completely turned off to prevent damaging other parts.
  2. Acer Nitro 5 AN515-55 SSD Replacement: étape 2, image 1 de 3 Acer Nitro 5 AN515-55 SSD Replacement: étape 2, image 2 de 3 Acer Nitro 5 AN515-55 SSD Replacement: étape 2, image 3 de 3
    • Flip the laptop on its back.
    • Remove the eleven 8 mm screws securing the back cover using the Phillips #1 screwdriver.
  3. Acer Nitro 5 AN515-55 SSD Replacement: étape 3, image 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: étape 3, image 2 de 2
    • Loosen the back cover using a plastic opening tool.
  4. Acer Nitro 5 AN515-55 SSD Replacement: étape 4, image 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: étape 4, image 2 de 2
    • Pull the back cover off and put it in a safe place.
    • A little bit of force is needed to pry open the clips at the corners of the laptop.
  5. Acer Nitro 5 AN515-55 SSD Replacement: étape 5, image 1 de 3 Acer Nitro 5 AN515-55 SSD Replacement: étape 5, image 2 de 3 Acer Nitro 5 AN515-55 SSD Replacement: étape 5, image 3 de 3
    • Remove the 2.6 mm screw that is holding down the SSD with a Phillips #0 screwdriver.
    • Make sure to ground yourself before working on the motherboard to prevent damage.
  6. Acer Nitro 5 AN515-55 SSD Replacement: étape 6, image 1 de 3 Acer Nitro 5 AN515-55 SSD Replacement: étape 6, image 2 de 3 Acer Nitro 5 AN515-55 SSD Replacement: étape 6, image 3 de 3
    • Gently pull out the damaged SSD.
  7. Acer Nitro 5 AN515-55 SSD Replacement: étape 7, image 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: étape 7, image 2 de 2
    • Slide in the new SSD.
    • Screw it in place.
  8. Acer Nitro 5 AN515-55 SSD Replacement: étape 8, image 1 de 2 Acer Nitro 5 AN515-55 SSD Replacement: étape 8, image 2 de 2
    • Put the back cover on and gently snap the clips back in.
    • Screw the back cover in place.
Follow the guide that comes with your new SSD to make sure your laptop recognizes your new SSD.
5 autres ont terminé cette réparation.
Solomon Mekuria
Membre depuis le 03/22/21
271 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S3-G14, Saloman Spring 2021 Membre de l'équipe UMass Dartmouth, Team S3-G14, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G14
1 membre
1 tutoriel rédigé
Un commentaire
This model is supposed to have 3 slots 2 for SSD and 1 for HDD, can you please point them out? Just add an extra SDD?
mayumidb - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 31
30 derniers jours : 192
Total : 8,369
