Aller au contenu principal
Acer Nitro 5 AN515-55-55M1 Speakers Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Bottom Cover: étape 1, image 1 de 1
    • Make sure the device is off and unplugged from power.
    • Flip the device so the bottom is facing up.
    • Remove 11 screws from the bottom case using a Phillips #1 screwdriver.
  2. Acer Nitro 5 AN515-55-55M1 Speakers Replacement: étape 2, image 1 de 2 Acer Nitro 5 AN515-55-55M1 Speakers Replacement: étape 2, image 2 de 2
    • Lift the top left and right corners up and away from the device.
    • This may require some force and will make harsh clicking sounds. This is normal; it's the plastic tabs separating from each other.
    • Remove the panel from the laptop.
  3. Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Speakers: étape 3, image 1 de 3 Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Speakers: étape 3, image 2 de 3 Acer Nitro 5 AN515-55-55M1 Speakers Replacement, Speakers: étape 3, image 3 de 3
    • Use an iFixit opening tool to unplug both speaker connectors from the motherboard.
  4. Acer Nitro 5 AN515-55-55M1 Speakers Replacement: étape 4, image 1 de 2 Acer Nitro 5 AN515-55-55M1 Speakers Replacement: étape 4, image 2 de 2
    • Lift the speakers straight up and out of their shells.
Samuel Rouillard
Membre depuis le 03/30/21
681 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-4, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-4, Mellen Spring 2022
UMASSD-MELLEN-S22S1G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 28
Total : 647
