Introduction
This guide will teach you how to change the Wi-Fi card in the Acer Nitro 5 AN515-55-55M1. You may need to perform this to upgrade your range and bandwidth speed. This repair may be helpful if you require a stronger internet connection.
Ce dont vous avez besoin
Turn the laptop over so its underside is up.
Use the PH#0 screw driver to remove all 7 mm the screws on the underside.
Pop the cover off around the edges.
Presque terminé !
