Aller au contenu principal
Acer Nitro 5 AN515-55-55M1 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-55-55M1 Wi-Fi Card Replacement, WI-FI Card: étape 1, image 1 de 3 Acer Nitro 5 AN515-55-55M1 Wi-Fi Card Replacement, WI-FI Card: étape 1, image 2 de 3 Acer Nitro 5 AN515-55-55M1 Wi-Fi Card Replacement, WI-FI Card: étape 1, image 3 de 3
    • Turn the laptop over so its underside is up.
    • Use the PH#0 screw driver to remove all 7 mm the screws on the underside.
    • Pop the cover off around the edges.
  2. Acer Nitro 5 AN515-55-55M1 Wi-Fi Card Replacement: étape 2, image 1 de 3 Acer Nitro 5 AN515-55-55M1 Wi-Fi Card Replacement: étape 2, image 2 de 3 Acer Nitro 5 AN515-55-55M1 Wi-Fi Card Replacement: étape 2, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the single 5 mm screw that secures the Wi-Fi card.
    • Remove the two attached wires from the Wi-Fi card.
    • Pull the Wi-Fi card horizontally out of its socket.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 69
Total : 870
