Aller au contenu principal
Acer Nitro 5 AN515-57 RAM Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: étape 1, image 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement, RAM: étape 1, image 2 de 2
    • Shut-down your laptop and unplug the battery connection.
    • Remove any other device attached to the laptop.
  2. Acer Nitro 5 AN515-57 RAM Replacement: étape 2, image 1 de 1
    • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
  3. Acer Nitro 5 AN515-57 RAM Replacement: étape 3, image 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement: étape 3, image 2 de 2
    • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
    • Make sure not to slide the tool too deep as it can damage the board.
  4. Acer Nitro 5 AN515-57 RAM Replacement: étape 4, image 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement: étape 4, image 2 de 2
    • Disconnect the battery by either using the iFixit opening tool or your fingers.
  5. Acer Nitro 5 AN515-57 RAM Replacement: étape 5, image 1 de 3 Acer Nitro 5 AN515-57 RAM Replacement: étape 5, image 2 de 3 Acer Nitro 5 AN515-57 RAM Replacement: étape 5, image 3 de 3
    • Use your fingers to pull the silver latches on either side of the RAM away from each other.
    • The RAM will pop up by a few centimeters.
    • Remove the RAM from the laptop.
  6. Acer Nitro 5 AN515-57 RAM Replacement: étape 6, image 1 de 1
    • Reconnect the battery pins
    • While reconnecting the battery, try not to touch the metal prongs.
  7. Acer Nitro 5 AN515-57 RAM Replacement: étape 7, image 1 de 2 Acer Nitro 5 AN515-57 RAM Replacement: étape 7, image 2 de 2
    • Place the back panel on to your laptop and gently press on it until it snaps in place.
    • Screw the back panel back in.
    • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
Ligne d'arrivée
Hanzala Mir
Membre depuis le 01/17/22
170 Réputation
1 tutoriel rédigé
Équipe
York University, Team S-18, Woodhouse Winter 2022 Membre de l'équipe York University, Team S-18, Woodhouse Winter 2022
YORK-WOODHOUSE-W22SSG18
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 56
30 derniers jours : 220
Total : 4,833
