Aller au contenu principal
Acer Nitro 5 AN517-51-56YW Touch Pad Replacement
Ce dont vous avez besoin
  1. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: étape 1, image 1 de 3 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: étape 1, image 2 de 3 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Bottom Cover: étape 1, image 3 de 3
    • Place the laptop upside-down so that the fans are facing away from you.
    • Remove the twelve 6.7 mm screws from the bottom cover using a Phillips #1 screwdriver.
    • Pry the bottom cover away from the laptop using a spudger.
  2. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: étape 2, image 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Battery: étape 2, image 2 de 2
    • Unplug the connection plug that attaches the battery to the motherboard.
    • Make sure to pull the connector safely so that it doesn't break.
    • Remove the two 4.7 mm screws using a Phillips #1 screwdriver.
  3. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: étape 3, image 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: étape 3, image 2 de 2
    • Remove the battery from the laptop.
    • Make sure that your laptop powers on before you begin reassembly. If it does not start, make sure the battery is firmly connected to the motherboard.
  4. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: étape 4, image 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement, Touch Pad: étape 4, image 2 de 2
    • Remove the two 3.7 mm screws from the silver bracing plate using a Phillips #1 screwdriver.
    • Detach the touch pad connector by lifting the clamp and pulling on the blue tab.
    • Lift the adhesive ribbon to be able to remove the touchpad.
    • Do not remove the ribbon completely, only the part that is on the touchpad.
  5. Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: étape 5, image 1 de 2 Acer Nitro 5 AN517-51-56YW Touch Pad Replacement: étape 5, image 2 de 2
    • Lift the touchpad towards you from the bottom.
Giovanni Lopez
Membre depuis le 09/15/22
88 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 3-1, Lane Fall 2022 Membre de l'équipe University of Memphis, Team 3-1, Lane Fall 2022
UM-LANE-F22S3G1
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 37
Total : 435
