Aller au contenu principal
Acer One 10 S1003-114M Track Pad Replacement
Ce dont vous avez besoin
  1. Acer One 10 S1003-114M Track Pad Replacement, Track Pad: étape 1, image 1 de 1
    • Open the screen.
  2. Acer One 10 S1003-114M Track Pad Replacement: étape 2, image 1 de 1
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Track Pad Replacement: étape 3, image 1 de 2 Acer One 10 S1003-114M Track Pad Replacement: étape 3, image 2 de 2
    • Turn over the keyboard and use the plastic pry tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Track Pad Replacement: étape 4, image 1 de 3 Acer One 10 S1003-114M Track Pad Replacement: étape 4, image 2 de 3 Acer One 10 S1003-114M Track Pad Replacement: étape 4, image 3 de 3
    • Remove ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Track Pad Replacement: étape 5, image 1 de 1
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Track Pad Replacement: étape 6, image 1 de 1
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Track Pad Replacement: étape 7, image 1 de 1
    • Use an opening tool to remove/peel off the adhesive tape from the trackpad electrical connector
  8. Acer One 10 S1003-114M Track Pad Replacement: étape 8, image 1 de 2 Acer One 10 S1003-114M Track Pad Replacement: étape 8, image 2 de 2
    • Use an opening tool to flip/pop the switch holding down the electric connector to the keyboard.
  9. Acer One 10 S1003-114M Track Pad Replacement: étape 9, image 1 de 2 Acer One 10 S1003-114M Track Pad Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the fine tip tweezers to remove the electrical connector for the trackpad. Pull gently.
  10. Acer One 10 S1003-114M Track Pad Replacement: étape 10, image 1 de 3 Acer One 10 S1003-114M Track Pad Replacement: étape 10, image 2 de 3 Acer One 10 S1003-114M Track Pad Replacement: étape 10, image 3 de 3
    • To free the retainer, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  11. Acer One 10 S1003-114M Track Pad Replacement: étape 11, image 1 de 1
    • To free the trackpad, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  12. Acer One 10 S1003-114M Track Pad Replacement: étape 12, image 1 de 1
    • Use a pair of fine tip tweezers to remove the adhesive metallic strap holding the trackpad to the keyboard.
  13. Acer One 10 S1003-114M Track Pad Replacement: étape 13, image 1 de 1
    • Gently remove the trackpad from the keyboard.
Karan Karthik
Membre depuis le 04/01/19
217 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G6, Harley Spring 2019 Membre de l'équipe IUPUI, Team S2-G6, Harley Spring 2019
IUPUI-HARLEY-S19S2G6
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 19
Total : 795
