Aller au contenu principal
Acer One 10 S1003-19GY Rear/Front Camera Replacement
Ce dont vous avez besoin
  1. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: étape 1, image 1 de 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement, Back Panel: étape 1, image 2 de 2
    • Power off the device and make sure it is disconnected from any external devices.
    • Use a plastic opening tool to create a gap between the front and back casing of the device.
    • Slowly maneuver the plastic tool around the entire perimeter of the tablet to separate the front and back.
  2. Acer One 10 S1003-19GY Rear/Front Camera Replacement: étape 2, image 1 de 1
    • Set the device screen side down and remove the back casing.
  3. Acer One 10 S1003-19GY Rear/Front Camera Replacement, Front/Rear Camera: étape 3, image 1 de 1
    • Locate the Rear Camera in the upper right hand corner of the motherboard.
  4. Acer One 10 S1003-19GY Rear/Front Camera Replacement: étape 4, image 1 de 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: étape 4, image 2 de 3 Acer One 10 S1003-19GY Rear/Front Camera Replacement: étape 4, image 3 de 3
    • Using a relatively thin flat head screwdriver, pry the camera connection from the motherboard.
    • The connection should remove easily as it just snaps to the motherboard.
  5. Acer One 10 S1003-19GY Rear/Front Camera Replacement: étape 5, image 1 de 1
    • Remove the five screws on the outer edge of the motherboard using a Phillips #0 screwdriver.
  6. Acer One 10 S1003-19GY Rear/Front Camera Replacement: étape 6, image 1 de 2 Acer One 10 S1003-19GY Rear/Front Camera Replacement: étape 6, image 2 de 2
    • Open the black flap on the connection and gently pull the ribbon from it.
    • Slightly raise the motherboard from the upper side to remove the camera as shown.
Trey Wintzinger
Membre depuis le 09/04/18
605 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 373
