Aller au contenu principal
Acer Predator 17 G9-791 Display Replacement
Ce dont vous avez besoin
  1. Acer Predator 17 G9-791 Display Replacement, Service Panel: étape 1, image 1 de 1
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Display Replacement: étape 2, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 2, image 2 de 2
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Display Replacement: étape 3, image 1 de 1
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Display Replacement, Bottom Case: étape 4, image 1 de 3 Acer Predator 17 G9-791 Display Replacement, Bottom Case: étape 4, image 2 de 3 Acer Predator 17 G9-791 Display Replacement, Bottom Case: étape 4, image 3 de 3
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Display Replacement: étape 5, image 1 de 1
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Display Replacement: étape 6, image 1 de 1
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Display Replacement: étape 7, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 7, image 2 de 2
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Display Replacement, Battery: étape 8, image 1 de 1
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Display Replacement: étape 9, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 9, image 2 de 2
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Display Replacement: étape 10, image 1 de 1
    • Gently lift the battery and remove it from the device.
  11. Acer Predator 17 G9-791 Display Replacement, Fan Assembly: étape 11, image 1 de 2 Acer Predator 17 G9-791 Display Replacement, Fan Assembly: étape 11, image 2 de 2
    • Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
  12. Acer Predator 17 G9-791 Display Replacement: étape 12, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 12, image 2 de 2
    • Unscrew the six Phillips #0 screws enough to loosen the assembly from the motherboard.
  13. Acer Predator 17 G9-791 Display Replacement: étape 13, image 1 de 3 Acer Predator 17 G9-791 Display Replacement: étape 13, image 2 de 3 Acer Predator 17 G9-791 Display Replacement: étape 13, image 3 de 3
    • Detach the left fan's cord from the motherboard.
  14. Acer Predator 17 G9-791 Display Replacement: étape 14, image 1 de 3 Acer Predator 17 G9-791 Display Replacement: étape 14, image 2 de 3 Acer Predator 17 G9-791 Display Replacement: étape 14, image 3 de 3
    • Detach the right fan's cord from the motherboard.
  15. Acer Predator 17 G9-791 Display Replacement: étape 15, image 1 de 3 Acer Predator 17 G9-791 Display Replacement: étape 15, image 2 de 3 Acer Predator 17 G9-791 Display Replacement: étape 15, image 3 de 3
    • Lift the fan assembly up and out.
  16. Acer Predator 17 G9-791 Display Replacement, Display: étape 16, image 1 de 3 Acer Predator 17 G9-791 Display Replacement, Display: étape 16, image 2 de 3 Acer Predator 17 G9-791 Display Replacement, Display: étape 16, image 3 de 3
    • Push down on the back of the device to unclip this panel, removing it by pulling it out the back of the device.
  17. Acer Predator 17 G9-791 Display Replacement: étape 17, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 17, image 2 de 2
    • Remove two black 7 mm Phillips #0 screws from the left display bracket.
    • Remove the two silver 5 mm Phillips #0 screws from the left display bracket.
  18. Acer Predator 17 G9-791 Display Replacement: étape 18, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 18, image 2 de 2
    • Remove three silver 5 mm Phillips #0 screws from the right display bracket.
    • Remove one black 7 mm Phillips #0 screw from the right display bracket.
  19. Acer Predator 17 G9-791 Display Replacement: étape 19, image 1 de 3 Acer Predator 17 G9-791 Display Replacement: étape 19, image 2 de 3 Acer Predator 17 G9-791 Display Replacement: étape 19, image 3 de 3
    • Remove one 4.5 mm Phillips #0 screw from the WLAN card.
    • Pull the WLAN card out.
  20. Acer Predator 17 G9-791 Display Replacement: étape 20, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 20, image 2 de 2
    • Turn the device around.
    • Pull the black tab to disconnect one wire from the bottom of the motherboard.
  21. Acer Predator 17 G9-791 Display Replacement: étape 21, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 21, image 2 de 2
    • Opening the cover slightly, pull the bottom half of the device towards you.
  22. Acer Predator 17 G9-791 Display Replacement: étape 22, image 1 de 2 Acer Predator 17 G9-791 Display Replacement: étape 22, image 2 de 2
    • Separate the wire that was unplugged two steps ago from the bottom of the device.
    • This wire runs in a track and pulling on it slightly will separate it from the bottom half of the device.
    • When reinstalling, ensure this wire in placed back in its track before attempting to put the new display on the device.
Adeline Slocum
Membre depuis le 10/25/22
304 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 5-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G1
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 357
