Aller au contenu principal
Acer S200HL LCD Monitor Bundled Cable Connector Replacement
Ce dont vous avez besoin
  1. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: étape 1, image 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: étape 1, image 2 de 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: étape 2, image 1 de 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: étape 2, image 2 de 3 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: étape 2, image 3 de 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: étape 3, image 1 de 1
    • Gently lift the back panel away from the monitor.
  4. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: étape 4, image 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: étape 5, image 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement: étape 5, image 2 de 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: étape 6, image 1 de 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: étape 7, image 1 de 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: étape 7, image 2 de 2
    • Pull the bundled cable connector gently away from motherboard.
  8. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: étape 8, image 1 de 1
    • Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
2 autres ont terminé cette réparation.
Jeffrey Kong
Membre depuis le 09/22/14
809 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 12-3, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 12-3, Forte Fall 2014
CPSU-FORTE-F14S12G3
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 2,767
