Aller au contenu principal
Acer Spin 5 N17W2 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Spin 5 N17W2 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Acer Spin 5 N17W2 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Hard Drive Replacement: étape 2, image 1 de 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Hard Drive Replacement: étape 3, image 1 de 1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Hard Drive Replacement: étape 4, image 1 de 1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Hard Drive Replacement: étape 5, image 1 de 1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 1
    • Disconnect the hard drive and remove it from the device.
    • At the time of guide creation, the hard drive was not included in the device.
2 commentaires
You highlighted some random spot for the hard drive but you should have highlighted the empty m.2 slot which doesn’t even require you to remove the battery.
Peter Iliopoulos - Réponse
Agreed. This guide is pointless. Just a random, inaccurate guess. Why even bother putting this together if you don't know what you're talking about.
Stephen Feger - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 35
Total : 2,732
