Aller au contenu principal
Acer Spin 5 N17W2 Trackpad Replacement
Ce dont vous avez besoin
  1. Acer Spin 5 N17W2 Trackpad Replacement, Battery: étape 1, image 1 de 2 Acer Spin 5 N17W2 Trackpad Replacement, Battery: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
  2. Acer Spin 5 N17W2 Trackpad Replacement: étape 2, image 1 de 1
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Trackpad Replacement: étape 3, image 1 de 1
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Trackpad Replacement: étape 4, image 1 de 1
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Trackpad Replacement: étape 5, image 1 de 1
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Trackpad Replacement: étape 6, image 1 de 1
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Trackpad Replacement, Trackpad: étape 7, image 1 de 1
    • Using the blue spudger, pry the two black clips from the two ribbon cables on the bottom of the mouse pad.
  8. Acer Spin 5 N17W2 Trackpad Replacement: étape 8, image 1 de 1
    • Remove ribbon cables connected to the middle of the mouse pad.
    • Remove the adhesive tape from the left side of the mouse pad.
  9. Acer Spin 5 N17W2 Trackpad Replacement: étape 9, image 1 de 1
    • Using the phillips #1 screwdriver, remove the 4 screws securing the mouse pad.
  10. Acer Spin 5 N17W2 Trackpad Replacement: étape 10, image 1 de 1
    • Using your thumbs, push the mouse pad from the inside of the computer towards ur self and slide the mousepad out of the computer.
William
Membre depuis le 02/20/20
109 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 791
