Aller au contenu principal
Acer Spin 5 SP513-51-57TP Cooling Fan Replacement
Ce dont vous avez besoin
  1. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Battery: étape 1, image 1 de 1
    • Flip your laptop over so that the model sticker is facing upward towards the ceiling.
    • Make sure your computer is turned off before starting to avoid getting shocked.
  2. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 2, image 1 de 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the thirteen 6.5mm screws that secure the back cover.
  3. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 3, image 1 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 3, image 2 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 3, image 3 de 3
    • Use a plastic opening tool to gently separate the back cover from the laptop. A snapping sound will be heard as a signal that the clips are being disengaged.
    • Do not use any metal tools to pry open the device.
    • It is recommended that you start from one corner and run the tool along the edges of your laptop from corner to corner for a safe removal.
  4. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 4, image 1 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 4, image 2 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 4, image 3 de 3
    • Use a Phillips #1 screwdriver to remove two 4 mm screws that secure the battery.
  5. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 5, image 1 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 5, image 2 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 5, image 3 de 3
    • Use your hand to carefully pull out the wiring harness from its port that is located between the battery and the motherboard.
    • Remove the battery from the case.
  6. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: étape 6, image 1 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: étape 6, image 2 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement, Cooling Fan: étape 6, image 3 de 3
    • Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
  7. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 7, image 1 de 2 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 7, image 2 de 2
    • Using Phillips #1 screwdriver remove three 5 mm screws to remove the heatsink.
    • When removing the cooling fan, the heatsink component will stay connected.
  8. Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 8, image 1 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 8, image 2 de 3 Acer Spin 5 SP513-51-57TP Cooling Fan Replacement: étape 8, image 3 de 3
    • Using your hand, pull out wiring harness to disconnect the fan from the motherboard.
    • Lift the fan out of the case to remove it.
Anthony Vansell
Membre depuis le 01/24/20
872 Réputation
5 tutoriels rédigés
Équipe
Hufflepuff Membre de l'équipe Hufflepuff
Local Repair Groups
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 1,288
