Aller au contenu principal
Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement
Ce dont vous avez besoin
  1. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Back Cover: étape 1, image 1 de 1
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 2, image 1 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 2, image 2 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 2, image 3 de 3
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 3, image 1 de 1
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Battery: étape 4, image 1 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Battery: étape 4, image 2 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Battery: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 5, image 1 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 5, image 2 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 5, image 3 de 3
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 6, image 1 de 2 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 6, image 2 de 2
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 7, image 1 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 7, image 2 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 7, image 3 de 3
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 8, image 1 de 2 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 8, image 2 de 2
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  9. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Side Ports and Buttons: étape 9, image 1 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Side Ports and Buttons: étape 9, image 2 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement, Side Ports and Buttons: étape 9, image 3 de 3
    • Using tweezers, carefully grip the sensor cable by the white and red tab.
    • Using gentle pressure, remove the cable from its connection by pulling outward.
  10. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 10, image 1 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 10, image 2 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 10, image 3 de 3
    • Place your fingernail underneath the locking black tab of the ZIF connector on the USB/Side Port Board and pry it upwards to release the cable.
  11. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 11, image 1 de 2 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 11, image 2 de 2
    • Remove the ribbon interconnect cable from the connector.
  12. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 12, image 1 de 2 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 12, image 2 de 2
    • Remove the two 3.5mm screws that secure the side ports using a Phillips #00 screwdriver (PH00 bit).
  13. Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 13, image 1 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 13, image 2 de 3 Acer Spin 5 SP515-51GN-807G Side Port and Button Replacement: étape 13, image 3 de 3
    • Using tweezers, gently grip the middle of the board that contains the side ports and carefully pull out to remove it.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 1,467
