Aller au contenu principal
Acer Spin 7 SP714-51 Solid State Drive Replacement
Ce dont vous avez besoin
  1. Acer Spin 7 SP714-51 Solid State Drive Replacement, Solid State Drive: étape 1, image 1 de 1
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Solid State Drive Replacement: étape 2, image 1 de 1
    • You can now remove the back panel using your fingers or a spudger.
  3. Acer Spin 7 SP714-51 Solid State Drive Replacement: étape 3, image 1 de 1
    • Carefully unplug the battery connector so the laptop is safer to work with.
    • Make sure you pull it straight back.
  4. Acer Spin 7 SP714-51 Solid State Drive Replacement: étape 4, image 1 de 1
    • Once the back is open and the battery is disconnected, you should be able to see the SSD on the top right of the laptop if oriented as seen in the photo.
    • The removal of the SSD should be simple as there is only one 6 mm PH0 Phillips screw holding it in place.
    • Once the screw is removed, you may safely remove the SSD and replace it with your new one.
Zach Desrosiers
Membre depuis le 03/22/22
565 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 Membre de l'équipe UMass Dartmouth, Team 7-3, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 35
Total : 1,054
