Introduction
If your computer has been acting up recently. Every time you turn it on, it shuts down after just a minute or two, and we've noticed there's no sound during this process. We suspect the fan might not be working properly, causing the system to overheat. Let's explore this issue further, to keep our computer running smoothly you should follow the guide to replace the heat sink/fan.
Ce dont vous avez besoin
Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
Use a Phillips # 1 screwdriver to remove the two 5.9 mm screws that secure the fan.
