Aller au contenu principal
Acer Swift X N20C12 Trackpad Replacement
Ce dont vous avez besoin
  1. Acer Swift X N20C12 Trackpad Replacement, Lower Case: étape 1, image 1 de 1
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Trackpad Replacement: étape 2, image 1 de 1
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Trackpad Replacement, Battery: étape 3, image 1 de 1
    • Grasp the battery connector and pull it directly out of its socket.
    • Use a Phillips #1 screwdriver to remove the two 4.8 mm screws that secure the battery.
  4. Acer Swift X N20C12 Trackpad Replacement: étape 4, image 1 de 1
    • Lift the battery up and out of the chassis.
  5. Acer Swift X N20C12 Trackpad Replacement, Trackpad: étape 5, image 1 de 1
    • Use a Phillips # 1 screwdriver to remove the 2.9 mm screws that secure the trackpad.
    • Disconnect the trackpad connector.
  6. Acer Swift X N20C12 Trackpad Replacement: étape 6, image 1 de 1
    • Lift the trackpad up and out of the chassis.
Abrar
Membre depuis le 09/08/23
472 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 1-2, Pee Fall 2023 Membre de l'équipe Gateway, Team 1-2, Pee Fall 2023
GCC-PEE-F23S1G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 111
