Aller au contenu principal
Acer TravelMate TMB115-M-C99B Motherboard Replacement
Ce dont vous avez besoin
  1. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 2, image 1 de 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 2, image 2 de 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 2, image 3 de 3
    • Remove the thirteen 6mm Phillips screws using the #0 screwdriver.
    • Remove the back of the laptop.
  3. Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 3, image 1 de 1
    • Remove the two 7mm Phillips screws from the battery using the #0 screwdriver.
  4. Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 4, image 1 de 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 4, image 2 de 2
    • Unplug the battery from the motherboard.
  5. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: étape 5, image 1 de 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: étape 5, image 2 de 3 Acer TravelMate TMB115-M-C99B Motherboard Replacement, Hard Drive: étape 5, image 3 de 3
    • Carefully disconnect the hard drive from the motherboard.
  6. Acer TravelMate TMB115-M-C99B Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Disconnect the two wires from the Wi-Fi interface.
  7. Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 7, image 1 de 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 7, image 2 de 2
    • Remove one 6mm Phillips screw from the Wi-Fi interface using the #0 screwdriver.
  8. Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 8, image 1 de 1
    • Remove the Wi-Fi interface from the motherboard.
  9. Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 9, image 1 de 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 9, image 2 de 2
    • Remove the eight 7mm Phillips screws from the motherboard using the #0 screwdriver.
  10. Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 10, image 1 de 2 Acer TravelMate TMB115-M-C99B Motherboard Replacement: étape 10, image 2 de 2
    • Remove the motherboard.
Melissa Martinez
Membre depuis le 01/24/19
279 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S1-G5, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G5, White Winter 2019
CPSU-WHITE-W19S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 559
