Aller au contenu principal
Acer Travelmate 220 RAM Replacement
Ce dont vous avez besoin
  1. Acer Travelmate 220 RAM Replacement, RAM Chip: étape 1, image 1 de 1
    • Place the computer with the bottom facing up.
  2. Acer Travelmate 220 RAM Replacement: étape 2, image 1 de 3 Acer Travelmate 220 RAM Replacement: étape 2, image 2 de 3 Acer Travelmate 220 RAM Replacement: étape 2, image 3 de 3
    • Locate the larger cover panel in the upper left hand corner of the computer.
    • Locate the Phillips screw holding the large cover panel in place.
  3. Acer Travelmate 220 RAM Replacement: étape 3, image 1 de 2 Acer Travelmate 220 RAM Replacement: étape 3, image 2 de 2
    • Remove the located screw with the Phillips #00 screwdriver.
  4. Acer Travelmate 220 RAM Replacement: étape 4, image 1 de 1
    • Slide the large cover panel to the right, until you hear a click.
  5. Acer Travelmate 220 RAM Replacement: étape 5, image 1 de 2 Acer Travelmate 220 RAM Replacement: étape 5, image 2 de 2
    • Place the plastic opening tool in the gap created to the left of the large cover panel.
    • Pry the cover panel up and remove it from the computer.
  6. Acer Travelmate 220 RAM Replacement: étape 6, image 1 de 2 Acer Travelmate 220 RAM Replacement: étape 6, image 2 de 2
    • Locate the white plastic levers on each side of the two RAM chips.
  7. Acer Travelmate 220 RAM Replacement: étape 7, image 1 de 3 Acer Travelmate 220 RAM Replacement: étape 7, image 2 de 3 Acer Travelmate 220 RAM Replacement: étape 7, image 3 de 3
    • Locate the first RAM chip.
    • Push the plastic levers away from the first RAM chip.
  8. Acer Travelmate 220 RAM Replacement: étape 8, image 1 de 3 Acer Travelmate 220 RAM Replacement: étape 8, image 2 de 3 Acer Travelmate 220 RAM Replacement: étape 8, image 3 de 3
    • Lift the RAM chip from the compartment.
    • Repeat steps 7 and 8 to replace the second RAM chip.
2 autres ont terminé cette réparation.
Kevin A
Membre depuis le 10/04/11
55 Réputation
1 tutoriel rédigé
Équipe
UW Stout, Team 5-5, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 14
Total : 3,393
