Aller au contenu principal
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
Ce dont vous avez besoin
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 1, image 1 de 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 1, image 2 de 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 2, image 1 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 2, image 2 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 2, image 3 de 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 3, image 1 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 3, image 2 de 3 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: étape 3, image 3 de 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
Ligne d'arrivée
aaron thielk
Membre depuis le 10/10/10
1 903 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-13, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 membres
17 tutoriels rédigés
Un commentaire
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 9,352
