Aller au contenu principal
Adjusting Nishiki Aero II Seat
Ce dont vous avez besoin
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: étape 1, image 1 de 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: étape 1, image 2 de 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: étape 1, image 3 de 3
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: étape 2, image 1 de 2 Adjusting Nishiki Aero II Seat: étape 2, image 2 de 2
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: étape 3, image 1 de 1
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
Tobias Elder
Membre depuis le 04/25/13
113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 21-53, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 44
Total : 2,795
