Aller au contenu principal
Adjusting the alarm glass breakage microphone sensitivity
Ce dont vous avez besoin
  1. Adjusting the alarm glass breakage microphone sensitivity: étape 2, image 1 de 1
    • Once the glove box is out of the way, it's easy to spot the alarm unit. The green connector will be plugged into it. I had already unplugged it when I took this picture.
  2. Adjusting the alarm glass breakage microphone sensitivity: étape 3, image 1 de 1
    • It may be stubborn to get out because it is stuck down with double stick foam pads.
  3. Adjusting the alarm glass breakage microphone sensitivity: étape 4, image 1 de 1
    • Remove the 4 screws (may be under the foam strips). This is the bottom of the circuit board.
  4. Adjusting the alarm glass breakage microphone sensitivity: étape 5, image 1 de 1
    • Turn the board over and locate the 2 position dip switch.
    • This dip switch adjusts the glass breakage microphone sensitivity
    • Sensitivity settings:
    • 1 off & 2 off = high
    • 1 on & 2 off = mid (factory setting)
    • 1 off & 2 on = low
    • 1 on & 2 on = super low
3 autres ont terminé cette réparation.
mpeeples
Membre depuis le 04/04/10
184 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 20
Total : 2,564
