Introduction
This guide shows the steps required to replace the vibration motors in a PS3 Wireless Afterglow Controller.
Ce dont vous avez besoin
Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
Lift up and remove the controller back plate.
Carefully remove the battery by lifting it straight up from its place.
Use the soldering tool to heat the solder connecting the red and black vibration motor wires to the motherboard to detach the vibration motors.
Use this guide for further details on how to solder.
