Aller au contenu principal
Air Blasters Tek Six Barrel Replacement
Ce dont vous avez besoin
  1. Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: étape 1, image 1 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: étape 1, image 2 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws of the grey slider: étape 1, image 3 de 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: étape 2, image 1 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: étape 2, image 2 de 3 Air Blasters Tek Six Barrel Replacement, Remove screws in main  body: étape 2, image 3 de 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Barrel Replacement, Take the main body apart: étape 3, image 1 de 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: étape 3, image 2 de 3 Air Blasters Tek Six Barrel Replacement, Take the main body apart: étape 3, image 3 de 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Barrel Replacement, Remove the trigger: étape 4, image 1 de 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: étape 4, image 2 de 3 Air Blasters Tek Six Barrel Replacement, Remove the trigger: étape 4, image 3 de 3
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Air Blasters Tek Six Barrel Replacement, Removing the barrel: étape 5, image 1 de 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: étape 5, image 2 de 3 Air Blasters Tek Six Barrel Replacement, Removing the barrel: étape 5, image 3 de 3
    • Lift the barrel, pulling it out from under the black trigger catch
Joshua Taylor
Membre depuis le 09/22/14
118 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 3-1, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 membres
5 tutoriels rédigés
Un commentaire
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 440
