Aller au contenu principal
Air Conditioning Thermostat Replacement
Ce dont vous avez besoin
  1. Air Conditioning Thermostat Replacement, Turn Off the Power: étape 1, image 1 de 3 Air Conditioning Thermostat Replacement, Turn Off the Power: étape 1, image 2 de 3 Air Conditioning Thermostat Replacement, Turn Off the Power: étape 1, image 3 de 3
    • Before you begin, locate the circuit breaker switchboard for the housing unit.
    • Find the air conditioning breaker that’s typically labeled inside the breaker's panel cover.
    • Turn off the electrical breaker switch that supplies the air conditioning thermostat.
  2. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: étape 2, image 1 de 3 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: étape 2, image 2 de 3 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: étape 2, image 3 de 3
    • Separate the thermostat casing off of the wall plate. It should come off easily using your hands, but a pair of pliers can be used if it's being stubborn.
    • Take a picture using your phone's camera of the color-coded wiring, so it will be easier to re-attach the wiring to the new thermostat.
  3. Air Conditioning Thermostat Replacement: étape 3, image 1 de 3 Air Conditioning Thermostat Replacement: étape 3, image 2 de 3 Air Conditioning Thermostat Replacement: étape 3, image 3 de 3
    • Use the Flathead 3/32" 2.5 mm Screwdriver to separate the color coded wiring.
    • Use the Phillips or flathead screwdriver to separate and un-wrap each of the color coded wires. (For example: notice the yellow wire)
    • Use the Phillips or flathead screwdriver depending on the type of model, to remove the Phillips #0 Plus screw, in order to remove the base plate.
  4. Air Conditioning Thermostat Replacement: étape 4, image 1 de 3 Air Conditioning Thermostat Replacement: étape 4, image 2 de 3 Air Conditioning Thermostat Replacement: étape 4, image 3 de 3
    • Remove the old base plate of the thermostat.
    • Screw in the new base plate of the Thermostat using the Phillips or flathead screwdriver to screw in the Phillips #0 Plus screw drive.
    • Using the screwdriver; reconnect the color-coded wring based on the photo taken with your camera. (For example: Notice the yellow wiring)
  5. Air Conditioning Thermostat Replacement: étape 5, image 1 de 2 Air Conditioning Thermostat Replacement: étape 5, image 2 de 2
    • Use your fingers to wrap the copper around the terminal slots, Use your Flathead 3/32" 2.5 mm Screwdriver to tighten the terminal slots. (For example: Notice the yellow wiring)
    • Fasten the terminal slots using your Phillips Flathead 3/32" 2.5 mm Screwdriver.
  6. Air Conditioning Thermostat Replacement: étape 6, image 1 de 2 Air Conditioning Thermostat Replacement: étape 6, image 2 de 2
    • Place the new thermostat casing over the base plate.
    • Snap on the thermostat casing.
  7. Air Conditioning Thermostat Replacement: étape 7, image 1 de 3 Air Conditioning Thermostat Replacement: étape 7, image 2 de 3 Air Conditioning Thermostat Replacement: étape 7, image 3 de 3
    • Locate the circuit breaker switchboard for the housing unit.
    • Locate the air conditioning electrical breaker switch.
    • Turn on the electrical breaker switch that the air conditioning thermostat supplies.
Genesis
Membre depuis le 03/01/17
163 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 Membre de l'équipe USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017
USFSM-STEWART-S17S1G1
19 membres
22 tutoriels rédigés
Un commentaire
ما هو السبب خروج علامت E3 في اسبلت westtin
السبلت ٣ طن عمودي
Hassan Alkanan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 29
Total : 1,804
