Introduction
This guide explains how to reattach a vent cover if the original screw hole is too worn out to be re-used, or was incorrectly placed originally.
Typically, a vent cover attaches directly to a hole in the ductwork so that the drywall doesn't wear out during the process. Check to confirm this isn't an option before starting this procedure, as the vent will cover minor drywall issues and connecting to the duct work directly will save substantial time.
Ce dont vous avez besoin
Measure and mark a rectangle around the damaged drywall area using the carpenter's pencil.
After this process you'll have a repaired ceiling with vent attached, ready to paint.
