Aller au contenu principal
Air Hog Smash Bots Controller Motherboard Replacement
Ce dont vous avez besoin
  1. Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: étape 1, image 1 de 2 Air Hog Smash Bots Controller Motherboard Replacement, Front Panel: étape 1, image 2 de 2
    • Take out your controller and access to the back of the controller.
  2. Air Hog Smash Bots Controller Motherboard Replacement: étape 2, image 1 de 1
    • Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
  3. Air Hog Smash Bots Controller Motherboard Replacement: étape 3, image 1 de 1
    • Remove the 2 AAA batteries.
  4. Air Hog Smash Bots Controller Motherboard Replacement: étape 4, image 1 de 2 Air Hog Smash Bots Controller Motherboard Replacement: étape 4, image 2 de 2
    • Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
  5. Air Hog Smash Bots Controller Motherboard Replacement: étape 5, image 1 de 2 Air Hog Smash Bots Controller Motherboard Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to disconnect the front and back parts of the panel.
    • Some of the internal components may be displaced when opening the controller.
  6. Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: étape 6, image 1 de 2 Air Hog Smash Bots Controller Motherboard Replacement, Controller Motherboard: étape 6, image 2 de 2
    • Using the PH #0 bit, remove two 8 mm screws on the main board.
    • De-solder the LED wires from the motherboard.
    • Lift the motherboard with a spudger to remove it from the case.
Brittany Frecker
Membre depuis le 02/08/16
542 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Baechle Spring 2016 Membre de l'équipe IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 membres
14 tutoriels rédigés
Un commentaire
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
Ali Hori - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 177
