Aller au contenu principal
Air Hog Smash Bots Motor Replacement
Ce dont vous avez besoin
  1. Air Hog Smash Bots Motor Replacement, Batteries: étape 1, image 1 de 1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Motor Replacement: étape 2, image 1 de 1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Motor Replacement: étape 3, image 1 de 1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Motor Replacement, External Casing: étape 4, image 1 de 2 Air Hog Smash Bots Motor Replacement, External Casing: étape 4, image 2 de 2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Motor Replacement: étape 5, image 1 de 2 Air Hog Smash Bots Motor Replacement: étape 5, image 2 de 2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Motor Replacement: étape 6, image 1 de 1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Motor Replacement: étape 7, image 1 de 1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Motor Replacement: étape 8, image 1 de 2 Air Hog Smash Bots Motor Replacement: étape 8, image 2 de 2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Motor Replacement, Motor: étape 9, image 1 de 2 Air Hog Smash Bots Motor Replacement, Motor: étape 9, image 2 de 2
    • Using the Phillips #0 screwdriver, remove six 4.75mm screws.
  10. Air Hog Smash Bots Motor Replacement: étape 10, image 1 de 1
    • Use the soldering iron to remove the blue and green wire from the motor casing. Directions on how to solder can be found here.
Brittany Frecker
Membre depuis le 02/08/16
542 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Baechle Spring 2016 Membre de l'équipe IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 174
