Aller au contenu principal
Airox Legendair Battery Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: étape 1, image 1 de 1
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Battery Replacement: étape 3, image 1 de 1
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Battery Replacement: étape 4, image 1 de 1
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Battery Replacement, Battery: étape 6, image 1 de 1
    • Make sure to turn off the ventilator before starting the repair.
    • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
  5. Airox Legendair Battery Replacement: étape 7, image 1 de 1
    • Remove each attachment screw from the battery cover.
  6. Airox Legendair Battery Replacement: étape 8, image 1 de 1
    • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
  7. Airox Legendair Battery Replacement: étape 9, image 1 de 1
    • Extract the current battery and replace it with the new battery.
  8. Airox Legendair Battery Replacement: étape 10, image 1 de 1
    • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
  9. Airox Legendair Battery Replacement: étape 11, image 1 de 1
    • Switch the device to "Set Up Mode" by pressing the On/Off switch.
    • Hold the menu key until the menu options appear on the screen.
    • Select the "MAINTENANCE" option with cursor.
    • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
Caleb Erlenborn
Membre depuis le 04/09/20
174 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G15, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
3 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 407
