Aller au contenu principal
Akai Retro Boom CD player model CE2200 Speaker Replacement
Ce dont vous avez besoin
  1. Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: étape 1, image 1 de 3 Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: étape 1, image 2 de 3 Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Remove the batteries located under the radio by sliding open the removable panel.
  2. Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 2, image 1 de 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 2, image 2 de 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 2, image 3 de 3
    • Use a six inch Phillips #2 screwdriver to remove the screws that hold the clamshell body together.
    • There will be six (6) screws at the bottom of the speaker, one (1) screw in the CD player, and two (2) under the battery panel. A total of nine (9) screws.
    • Each screw is 12.7 millimeters.
  3. Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 3, image 1 de 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 3, image 2 de 3 Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 3, image 3 de 3
    • Use the plastic spudger or the Jimmy to gently pry open the plastic shell halves from each other.
    • The red boxes highlight the speakers you are replacing.
    • Be careful of loose wiring when prying the halves open.
  4. Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 4, image 1 de 2 Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 4, image 2 de 2
    • Unplug the small red connector from the circuit board.
    • Be firm with your pinch and pull gently.
  5. Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 5, image 1 de 2 Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 5, image 2 de 2
    • Carefully remove the speakers from their placeholders by lifting each speaker up.
    • Set removed speakers aside and recycle them later.
  6. Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 6, image 1 de 2 Akai Retro Boom CD player model CE2200 Speaker Replacement: étape 6, image 2 de 2
    • Insert new speakers where the old ones were located
    • Then connect the new speakers to the circuit board.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Charlotte Kong
Membre depuis le 09/30/19
148 Réputation
1 tutoriel rédigé
Équipe
CSU Fullerton, Team S1-G2, Bruce Fall 2019 Membre de l'équipe CSU Fullerton, Team S1-G2, Bruce Fall 2019
CSUF-BRUCE-F19S1G2
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 282
