Aller au contenu principal
Akaso EK7000 4K Battery Replacement
  1. Akaso EK7000 4K Battery Replacement, Battery: étape 1, image 1 de 2 Akaso EK7000 4K Battery Replacement, Battery: étape 1, image 2 de 2
    • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
  2. Akaso EK7000 4K Battery Replacement: étape 2, image 1 de 2 Akaso EK7000 4K Battery Replacement: étape 2, image 2 de 2
    • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
6 autres ont terminé cette réparation.
Annie Sun
Membre depuis le 02/05/19
436 Réputation
3 tutoriels rédigés
Équipe
UC Davis, Team S20-G2, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G2, Lore Winter 2019
UCD-LORE-W19S20G2
3 membres
4 tutoriels rédigés
2 commentaires
Thank you for the help actclly needed that help
Charisma Broughton - Réponse
I’ve been using my Akaso EK7000 Pro as a dashcam, I removed the battery and plugged the camera into the cars cigar lighter, now when I insert the battery the cover won’t go back on.
The battery will push down into place but when I let go to put the cover on the battery moves up and the cover is about one tenth of one millimetre too high to fit.
The camera does get quite warm when in use and I suspect the plastic of the battery chamber has slightly distorted preventing the battery going fully into it and allowing the cover to be put into place.
Do you have any suggestions how I can resolve this issue?
Glynn Sole - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 43
Total : 4,633
