Aller au contenu principal
  1. Locate the small indent on the lower left corner. Use your fingers or a small plastic opening tool to lift the back cover off. Use your fingers or a small plastic opening tool to lift the back cover off.
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Locate the indent between the battery and your phone. Use your finger or a small plastic opening tool to lift the battery free. Use your finger or a small plastic opening tool to lift the battery free.
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Using the Phillips screw driver, remove the 9 screws from the phone. Using the Phillips screw driver, remove the 9 screws from the phone. Using the Phillips screw driver, remove the 9 screws from the phone.
    • Using the Phillips screw driver, remove the 9 screws from the phone.
  4. Using your prying tool, place it between the screen and the back cover and pry it open.
    • Using your prying tool, place it between the screen and the back cover and pry it open.
  5. Disconnect the camera from the mother board with your prying tool. Disconnect the camera from the mother board with your prying tool.
    • Disconnect the camera from the mother board with your prying tool.
  6. Remove both of this cables located on the bottom left corner of the phone. Remove both of this cables located on the bottom left corner of the phone. Remove both of this cables located on the bottom left corner of the phone.
    • Remove both of this cables located on the bottom left corner of the phone.
  7. Remove the volume and power button using your prying tool. Go underneath the bronze plate with your prying tool and carefully pry it off.
    • Remove the volume and power button using your prying tool.
    • Go underneath the bronze plate with your prying tool and carefully pry it off.
  8. Remove this pice that is to the right of the camera with your prying tool.
    • Remove this pice that is to the right of the camera with your prying tool.
  9. Remove this two pieces by using your tweezers. Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
    • Remove this two pieces by using your tweezers.
    • Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
  10. Using you prying tool, go in-between the phone.
    • Using you prying tool, go in-between the phone.
    • Carefully pry it off.
Yahriel Negrete
Membre depuis le 08/02/2018
291 Réputation
2 tutoriels rédigés
Équipe
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 172
