Aller au contenu principal
Alienware 15 M.2 Solid State Drive
Ce dont vous avez besoin
    • After turning the computer off, close the display and turn the computer over.
  1. Alienware 15 M.2 Solid State Drive, Remove the Back Panel Screws and Lift: étape 2, image 1 de 1
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
  2. Alienware 15 M.2 Solid State Drive, Optional: Disconnect the Battery: étape 3, image 1 de 1
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
  3. Alienware 15 M.2 Solid State Drive, Remove Solid-State screw: étape 4, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION : Solid-state drives are fragile. Exercise care when handling the solid-state drives, and avoid touching the gold contact pins.
    • CAUTION : To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
    • Remove the screw that secures the solid-state drive to the computer base.
  4. Alienware 15 M.2 Solid State Drive, Slide the Solid-State Drive: étape 5, image 1 de 1
    • Slide and remove the solid-state drive from the solid-state drive slot.
  5. Alienware 15 M.2 Solid State Drive, Slide the Solid-state Drive: étape 6, image 1 de 1
    • Slide the solid-state drive into the solid-state drive slot.
  6. Alienware 15 M.2 Solid State Drive, Align the screw: étape 7, image 1 de 1
    • Align the screw hole on the solid-state drive with the screw hole on the computer base.
  7. Alienware 15 M.2 Solid State Drive, Replace the Screw: étape 8, image 1 de 1
    • Replace the screw that secures the solid-state drive to the computer base.
To reassemble your device, screw the base panel on again.
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 361
