Aller au contenu principal
Alienware 15 R2 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Alienware 15 R2 Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 1 de 3 Alienware 15 R2 Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 2 de 3 Alienware 15 R2 Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 3 de 3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the center of the rear panel. Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Use plastic opening tool to disconnect battery cable.
  3. Alienware 15 R2 Wi-Fi Card Replacement: étape 3, image 1 de 2 Alienware 15 R2 Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Remove the 6.0 mm Phillips #0 screw on the Wifi card. Disconnect the white and black wires, then slide the card out.
Jarid Williams
Membre depuis le 09/18/19
208 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 12
Total : 794
