Aller au contenu principal
Alienware 17 R2 Screen Replacement
Ce dont vous avez besoin
  1. Alienware 17 R2  Screen Replacement, Display: étape 1, image 1 de 1
    • Put the laptop on a hard surface.
    • Make sure that the Alienware is not plugged into any power source.
    • First, we need to unplug the battery.
  2. Alienware 17 R2  Screen Replacement: étape 2, image 1 de 2 Alienware 17 R2  Screen Replacement: étape 2, image 2 de 2
    • To unplug the battery, turn the computer upside down.
    • Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
  3. Alienware 17 R2  Screen Replacement: étape 3, image 1 de 2 Alienware 17 R2  Screen Replacement: étape 3, image 2 de 2
    • Gently, pull the cover up and slide it off.
  4. Alienware 17 R2  Screen Replacement: étape 4, image 1 de 3 Alienware 17 R2  Screen Replacement: étape 4, image 2 de 3 Alienware 17 R2  Screen Replacement: étape 4, image 3 de 3
    • Now, you are going to look for a yellow tag.
    • Unplug the black wire that has the yellow tag.
    • This with successfully disconnect your battery.
  5. Alienware 17 R2  Screen Replacement: étape 5, image 1 de 2 Alienware 17 R2  Screen Replacement: étape 5, image 2 de 2
    • Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
    • Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
  6. Alienware 17 R2  Screen Replacement: étape 6, image 1 de 1
    • No you will unscrew the 2mm screws on the top and bottom side of the screen.
  7. Alienware 17 R2  Screen Replacement: étape 7, image 1 de 1
    • Tilt the screen forward towards the keyboard.
    • Disconnect the plug that is connecting the screen to the main body.
  8. Alienware 17 R2  Screen Replacement: étape 8, image 1 de 1
    • Gently, lift the display away from the laptop.
Luis Garcia
Membre depuis le 09/20/17
402 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 23
Total : 3,096
