Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
In this guide, we will be showing you how to remove and replace the Hard Drive.
Pièces
Aucune pièce spécifiée.
  1. WARNING :  Before working inside your computer, read the  safety information that shipped with your computer and  follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions  in After Working Inside Your Computer.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  2. Note the hard-drive cable routing and remove the cable from the routing guides on the computer base.
    • Note the hard-drive cable routing and remove the cable from the routing guides on the computer base.
  3. Remove the screws that secure the hard-drive assembly to the computer base.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  4. Lift the hard-drive assembly off the computer base.
    • Lift the hard-drive assembly off the computer base.
  5. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  6. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  7. Disconnect the interposer from the hard drive. Disconnect the interposer from the hard drive.
    • Disconnect the interposer from the hard drive.
  8. Connect the new interposer to the hard drive.
    • Connect the new interposer to the hard drive.
  9. Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  10. Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
    • Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
  11. Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Replace the screws that secure the hard-drive assembly to the computer base.
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Route the hard-drive cable  through the routing guides on the computer base.
    • Route the hard-drive cable through the routing guides on the computer base.
  14. Connect the hard-drive cable to the system board.
    • Connect the hard-drive cable to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 18/12/2017
72 516 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
21 membres
1 824 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 297
