Aller au contenu principal
Introduction
This guide will show you how to replace your Hard Drive.
Pièces
Aucune pièce spécifiée.
  1. Make sure the laptop is unplugged from any power source.
    • Make sure the laptop is unplugged from any power source.
    • Put the laptop facing down on a hard surface.
  2. Unscrew the two 6mm screws on the bottom side of the laptop. Lift up the back cover and slide towards you. Lift up the back cover and slide towards you.
    • Unscrew the two 6mm screws on the bottom side of the laptop.
    • Lift up the back cover and slide towards you.
  3. Locate the Hard Drive Locate the Hard Drive
    • Locate the Hard Drive
  4. Remove the screws that connect the SSD Bay to the laptop
    • Remove the screws that connect the SSD Bay to the laptop
  5. Unscrew the three screws holding the hard drive
    • Unscrew the three screws holding the hard drive
  6. Unscrew the four screws on the long sides of the hard drive casing Unscrew the four screws on the long sides of the hard drive casing
    • Unscrew the four screws on the long sides of the hard drive casing
  7. Now that the hard drive casing is off, carefully unplug the hard drive from the laptop Your hard drive has now been  successfully removed from your device Your hard drive has now been  successfully removed from your device
    • Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
    • Your hard drive has now been successfully removed from your device
Luis Garcia
Membre depuis le 20/09/2017
402 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 732
