Aller au contenu principal
Introduction
In this guide, we will be showing you how to remove and replace the Memory Modules.
Pièces
Aucune pièce spécifiée.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the base panel.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Slide and remove the memory module from the memory-module slot. Slide and remove the memory module from the memory-module slot.
    • Slide and remove the memory module from the memory-module slot.
  3. Align the notch on the new memory module with the tab on the memory- module slot.
    • Align the notch on the new memory module with the tab on the memory- module slot.
  4. Slide the memory module firmly into the slot at an angle and press the  memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • If you do not hear the click, remove the memory module and reinstall it.
Terrence15
Membre depuis le 18/12/2017
73 042 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
37 membres
2 022 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 253
