Introduction
This guide will teach you how to replace your RAM card allowing you to upgrade or simply replace your card.
Ce dont vous avez besoin
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
