Aller au contenu principal
Alienware 17 R4 Solid State Drive (SSD) Replacement
Ce dont vous avez besoin
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: étape 1, image 1 de 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 2, image 1 de 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 2, image 2 de 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): étape 3, image 1 de 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): étape 3, image 2 de 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): étape 3, image 3 de 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 4, image 1 de 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 4, image 2 de 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 4, image 3 de 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 5, image 1 de 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 5, image 2 de 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 5, image 3 de 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 6, image 1 de 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 6, image 2 de 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: étape 7, image 1 de 2 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: étape 7, image 2 de 2
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 8, image 1 de 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: étape 8, image 2 de 2
    • Slide the solid state drive towards yourself to prevent damage to the card.
3 autres ont terminé cette réparation.
Hector Mendez III
Membre depuis le 09/11/17
1 280 Réputation
8 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 membres
9 tutoriels rédigés
Un commentaire
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 33
Total : 6,715
