Aller au contenu principal
Alienware Aurora A5 SSD Replacement
Ce dont vous avez besoin
  1. Alienware Aurora A5 SSD Replacement, SSD: étape 1, image 1 de 2 Alienware Aurora A5 SSD Replacement, SSD: étape 1, image 2 de 2
    • Power off the computer.
    • To ensure the PC is completely off, remove the cables at the back of the PC.
  2. Alienware Aurora A5 SSD Replacement: étape 2, image 1 de 3 Alienware Aurora A5 SSD Replacement: étape 2, image 2 de 3 Alienware Aurora A5 SSD Replacement: étape 2, image 3 de 3
    • Lift the black latch at the back of the PC to pop open the side cover.
    • Carefully remove the side cover by lifting it up.
  3. Alienware Aurora A5 SSD Replacement: étape 3, image 1 de 2 Alienware Aurora A5 SSD Replacement: étape 3, image 2 de 2
    • Unlock both tabs on the back of the PC by pushing them up.
    • Remove the power supply latch to get access to the inside.
  4. Alienware Aurora A5 SSD Replacement: étape 4, image 1 de 3 Alienware Aurora A5 SSD Replacement: étape 4, image 2 de 3 Alienware Aurora A5 SSD Replacement: étape 4, image 3 de 3
    • Remove the black plastic part by pushing it down and then pulling it towards you.
    • Unlock the blue latch and pull to remove the graphics card.
  5. Alienware Aurora A5 SSD Replacement: étape 5, image 1 de 3 Alienware Aurora A5 SSD Replacement: étape 5, image 2 de 3 Alienware Aurora A5 SSD Replacement: étape 5, image 3 de 3
    • Use the Phillips #1 screwdriver to remove the 3.7 mm screw and remove the old M2 SSD.
Ensure that you tightly screwed on the M2 SSD and that you inserted the graphics card back to its position so that the PC runs smoothly with no problems. Once you have completed all the steps and reconnected the cables you have successfully replaced the NVMe M2 SSD and your PC is ready to be turned on!
5 autres ont terminé cette réparation.
Sarah Mohammed
Membre depuis le 05/10/21
232 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G17, O'Regan Summer 2021 Membre de l'équipe York University, Team S1-G17, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G17
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 148
Total : 1,901
