Aller au contenu principal
Alienware M11x Display Assembly Replacement
Ce dont vous avez besoin
  1. Alienware M11x Display Assembly Replacement, Introduction: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • NOTE: Dell or Alienware does not guarantee compatibility or provide support for hard drives from sources other than Dell.
    • NOTE: If you are installing a hard drive from a source other than Dell or Alienware, you need to install an operating system, drivers, and utilities on the new hard drive.
  2. Alienware M11x Display Assembly Replacement, Loosen the Screws: étape 2, image 1 de 1
    • Loosen the two captive screws that secure the hard-drive assembly to the computer base.
  3. Alienware M11x Display Assembly Replacement, Disconnecting the Hard-Drive: étape 3, image 1 de 1
    • Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
  4. Alienware M11x Display Assembly Replacement, Lifting the Hard-Drive Assembly: étape 4, image 1 de 1
    • Lift the hard-drive assembly out of the computer base.
  5. Alienware M11x Display Assembly Replacement, Removing the Screws from the Hard-Drive: étape 5, image 1 de 1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  6. Alienware M11x Display Assembly Replacement, Removing the Bracket: étape 6, image 1 de 1
    • Lift the hard drive away from the hard-drive bracket.
  7. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: étape 7, image 1 de 1
    • Place the NEW hard drive in the hard-drive bracket.
  8. Alienware M11x Display Assembly Replacement, Replace the Screws: étape 8, image 1 de 1
    • Replace the four screws that secure the hard-drive to the hard-drive bracket.
  9. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: étape 9, image 1 de 1
    • Place the hard-drive assembly in the computer base.
  10. Alienware M11x Display Assembly Replacement, Connecting the Hard-Drive Assembly: étape 10, image 1 de 1
    • Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
  11. Alienware M11x Display Assembly Replacement, Securing the Screws: étape 11, image 1 de 1
    • Tighten the two captive screws that secure the hard-drive assembly to the computer base.
Ligne d'arrivée
2 autres ont terminé cette réparation.
darrius
Membre depuis le 03/26/18
5 213 Réputation
30 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 465
