Aller au contenu principal
Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce spécifiée.
  1. Turn the computer off.
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Loosen the two 6.35 mm size 1 Phillips screws on the back cover. The two screws are spring loaded and will not separate from the cover. Slide the back cover towards you and then  lift upwards to remove.
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Pull up on the black tab on the battery to reveal the connection between the battery and laptop. Pull up on the white connector to disconnect it from the laptop. The battery is now free to remove from the laptop and can be set aside.
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Note the routing of the WirelessHD card (optional) and mini-card antenna cables and remove them from the routing guides on the computer base.
  6. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  7. NOTE: The WirelessHD card is optional and may not be present in your computer.
    • NOTE: The WirelessHD card is optional and may not be present in your computer.
    • Turn the computer over and open the display as far as possible.
  8. Make sure the Center-Control Cover, the Keyboard and the Palm-Rest Assembly are removed.
    • Make sure the Center-Control Cover, the Keyboard and the Palm-Rest Assembly are removed.
    • Using the pull-tab, disconnect the display cable from the connector on the system board.
  9. Disconnect the logo-board cable from the connector on the system board.
    • Disconnect the logo-board cable from the connector on the system board.
  10. Gently peel the display cable and the logo-board cable from the system board.
    • Gently peel the display cable and the logo-board cable from the system board.
  11. Remove the screws that secure the display assembly to the computer base.
    • Remove the screws that secure the display assembly to the computer base.
  12. Gently slide the WirelessHD (optional) and mini-card antenna cables out through the slot on the computer base.
    • Gently slide the WirelessHD (optional) and mini-card antenna cables out through the slot on the computer base.
    • Lift the display assembly off the computer.
  13. Slide the WirelessHD (optional) and mini-card antenna cables through the slot on the computer base.
    • Slide the WirelessHD (optional) and mini-card antenna cables through the slot on the computer base.
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
    • NOTE: Ensure that no cables lie between the display assembly and the computer base.
  14. Connect the display cable and the logo-board cable to the connectors on the system board.
    • Connect the display cable and the logo-board cable to the connectors on the system board.
Terrence15
Membre depuis le 18/12/2017
70 858 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
930 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 37
Total : 446
