Aller au contenu principal
Alienware M14xR2 RAM Replacement
Ce dont vous avez besoin
  1. Alienware M14xR2 RAM Replacement, Battery: étape 1, image 1 de 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 RAM Replacement: étape 2, image 1 de 3 Alienware M14xR2 RAM Replacement: étape 2, image 2 de 3 Alienware M14xR2 RAM Replacement: étape 2, image 3 de 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 RAM Replacement: étape 3, image 1 de 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 RAM Replacement: étape 4, image 1 de 3 Alienware M14xR2 RAM Replacement: étape 4, image 2 de 3 Alienware M14xR2 RAM Replacement: étape 4, image 3 de 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 RAM Replacement, Optical Drive: étape 5, image 1 de 3 Alienware M14xR2 RAM Replacement, Optical Drive: étape 5, image 2 de 3 Alienware M14xR2 RAM Replacement, Optical Drive: étape 5, image 3 de 3
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
  6. Alienware M14xR2 RAM Replacement, RAM: étape 6, image 1 de 3 Alienware M14xR2 RAM Replacement, RAM: étape 6, image 2 de 3 Alienware M14xR2 RAM Replacement, RAM: étape 6, image 3 de 3
    • Unscrew the two 6.35 mm size 1 screws.
    • Lift up and remove the panel covering the RAM sticks.
  7. Alienware M14xR2 RAM Replacement: étape 7, image 1 de 2 Alienware M14xR2 RAM Replacement: étape 7, image 2 de 2
    • Push outward on both prongs that secure the RAM sticks in place.
    • The RAM sticks will rise upward when released from the prongs.
  8. Alienware M14xR2 RAM Replacement: étape 8, image 1 de 2 Alienware M14xR2 RAM Replacement: étape 8, image 2 de 2
    • Grab and pull the RAM sticks up and out of their casing and set them aside.
4 autres ont terminé cette réparation.
Eugene Park
Membre depuis le 09/30/13
195 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-4, Forte Fall 2013 Membre de l'équipe Cal Poly, Team 13-4, Forte Fall 2013
CPSU-FORTE-F13S13G4
5 membres
6 tutoriels rédigés
3 commentaires
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - Réponse
I meaned r1 model
Yo, man! If my RAM slot is damaged somehow, is there any possibility to change/repair it? It won't detect a RAM card, keeps beeping 4 times at the start.
tasanov - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 2,227
