Aller au contenu principal
Alienware M15x Hard Drive Replacement
Ce dont vous avez besoin
  1. Alienware M15x Hard Drive Replacement, Battery: étape 1, image 1 de 3 Alienware M15x Hard Drive Replacement, Battery: étape 1, image 2 de 3 Alienware M15x Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x Hard Drive Replacement, Compartment Door: étape 2, image 1 de 2 Alienware M15x Hard Drive Replacement, Compartment Door: étape 2, image 2 de 2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x Hard Drive Replacement: étape 3, image 1 de 3 Alienware M15x Hard Drive Replacement: étape 3, image 2 de 3 Alienware M15x Hard Drive Replacement: étape 3, image 3 de 3
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Use Phillips #1 screwdriver to loosen the four screws on the hard drive enclosure.
  5. Alienware M15x Hard Drive Replacement: étape 5, image 1 de 2 Alienware M15x Hard Drive Replacement: étape 5, image 2 de 2
    • Once the screws are loosened use the "PULL" tab to remove the current hard drive from the computer.
  6. Alienware M15x Hard Drive Replacement: étape 6, image 1 de 2 Alienware M15x Hard Drive Replacement: étape 6, image 2 de 2
    • Remove the four small screws indicated to remove the casing to the hard drive.
  7. Alienware M15x Hard Drive Replacement: étape 7, image 1 de 1
    • Now take off the SATA converter and then connect it to the drive you would like to replace it with.
David Sann
Membre depuis le 01/22/18
111 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S11-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 832
