Aller au contenu principal
Introduction
This guide will explain how to carefully and safely remove the RAM from an Alienware M15x laptop.
  1. Alienware M15x RAM Replacement, Battery: étape 1, image 1 de 3 Alienware M15x RAM Replacement, Battery: étape 1, image 2 de 3 Alienware M15x RAM Replacement, Battery: étape 1, image 3 de 3
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x RAM Replacement, Compartment Door: étape 2, image 1 de 2 Alienware M15x RAM Replacement, Compartment Door: étape 2, image 2 de 2
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x RAM Replacement: étape 3, image 1 de 3 Alienware M15x RAM Replacement: étape 3, image 2 de 3 Alienware M15x RAM Replacement: étape 3, image 3 de 3
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x RAM Replacement, RAM: étape 4, image 1 de 1
    • Remove the two indicated screws for the RAM cover.
  5. Alienware M15x RAM Replacement: étape 5, image 1 de 1
    • Push the two retaining clips on either side of the ram outwards, allowing the RAM chip to pop up.
  6. Alienware M15x RAM Replacement: étape 6, image 1 de 1
    • Pull it straight out of its pocket.
  7. Alienware M15x RAM Replacement: étape 7, image 1 de 1
    • Repeat the same process if there are additional RAM chips.
Aria Saberi
Membre depuis le 22/01/2018
121 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S11-G3, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 310
